Robocut icon meanings
brianoats
Mar 19, 2008
Boston
Hello,
I have 3 icons I don't know the meaning of.
0.20 Mpa, as well as the other two. Thanks all.
I am not sure about the others, but the 0.20 MPa one is the filter pressure. The manual should specify a maximum value for it and if you reach that value, you need to change filters.
Thanks for the info. My maintenance page tells me the filters are at the end of their life. So is why Mpa is flashing to purple. That explains it. Thanks...
The yellow one with the down arrow means a user specified maintenance interval is up. On the right side of the Maintenance page is where those are set.
I have one set for 80 hours of on time as a reminder to clean the dust screen on the chiller.
I'll have to look into the other one.
Voltian is correct, the down arrow thing means a service interval on your maintenance page is up.
The sun/snowflake is a thing only on the newer machines. It's some kind of automatic temperature control, it adjusts some things depending on either ambient or DI water temp. No idea if it actually helps anything.
