Serrations programing on wire edm
Likes Likes:  0
Results 1 to 6 of 6
    Feb 2019
    CROATIA
    22
    Default Serrations programing on wire edm
    I need to make serrations on one long part and wire edm is only machine that i can do it on. Machine is fanuc and I'm not good with g codes. Is there a code for repeating sections? Like i program one line or one serration and just add code that says repeat this 123 times?
    Jun 2014
    WEST MICHIGAN
    25
    8
    Quote Originally Posted by Nero81 View Post
    You need to do a incrementall program than copy paste 10 times then copy paste that 10 times
    Sent from my LM-X410PM using Tapatalk
    Feb 2019
    CROATIA
    22
    That could work. Thnx
    Jun 2014
    WEST MICHIGAN
    25
    8
    If you have graph on your machine you could make a point or some geometry signifying the correct last point of cut at end of serations to be sure you dont cut one too many and verify
    Feb 2019
    CROATIA
    22
    No needed, it can only go "in empty"
    Jan 2003
    UK
    863
    446
    434
    There is a Post Processor in FeatureCAM that I use with my Fanuc Tapecut Model M to do such things.
