Hi Dixon:
On these older manual sinkers, the spark gap conditions have to be set manually in order to get the proper balance between spark energy, spark frequency, and spark duration.
The settings you choose depend on how big the surface area of your electrode is, how fast you hope to burn, how much electrode wear you can tolerate, and what surface finish you hope to achieve.
The capacitor box allows you to switch a range of capacitor values into the spark generating circuit, and the capacitance acts a bit like a dam or a valve; allowing the spark energy to build up to a higher threshold before it lets go and blasts a bit of the workpiece away.
The result is faster cutting, but at the expense of increased electrode wear and a rougher surface finish.
When you don't care how much wear you have; say you're burning out a broken tap with a simple tube electrode; that's when you can pour the coals to it and use the capacitor box.
When you are burning a mold cavity with a complex electrode that took hours to make, that's when you set your priorities differently and accept slower burns to preserve the expensive electrode.
That's it in a nutshell (the simple version).
Cheers
Marcus
