kamyabzahedi
- Oct 11, 2021
Hello guys.
We have two Charmilles Robofil 330F machines in our workshop.The problem we have with them is in the Skim cuts (E18) for example when we are machining locator pin holes feed-rate of skim cut machining reach to 15 mm/min on some points of profile and machined hole is freely loose in top and tight in bottom .Both of machine have the same problem. We have checked wire tension ,contact surface and changed top wire guide on one machine but the problem not solved.
thank you
thank you
