L
Luke.kerbey
Guest
I’m hoping someone can help me, this should be easy to answer but it’s got me stuck.
I’m doing some sparking in a tight space @45 degrees and can’t use the machines standard g24 retraction where it retracts outside of the machining path when difficult conditions occur. As I’ll hit the other side of my work piece.
I manually changed to g25 from g24 in the NC edit and my machine acknowledges this when running a simple NC generated program. And all is good in this instance.
However I’m also trying to stitch 2 programs together in the multi Machining but the multi machining won’t acknowledge my override in the NC edit.
My knowledge is limited on the multi machining software and the book hasn’t help me in this respect.
So, can anyone explain what I need to change or how I need to format the multi machining program in order to stop the G24 retractions?
