nlancaster
- Oct 8, 2018
We have a part that we run a batch of 5 at a time.
Every part needs to be probed for center and that takes extra time because T91 waits for the tank to drain, but the tank is already drained.
Is there a code we can use on certain threading operations to skip the tank drain time? We don't want to remove tank drain from the normal threading operation because later we do thread repeatedly while the tank is full, and draining a bit first allows threading to be more reliable.
