D
D. Thomas
Guest
1994 vintage with TX 22 control. Been sitting for a year, just now firing it up for the first time. In manual mode, when I go to jog an axis, I get aformentioned error each time. Then if I press ST on the hand control, to disable that function, and then try to jog, I get an axis overload error and it says to reset "heat" switch. Dunno how.
All ran perfectly a year ago before disconnect, both memory back up batteries still at full 3.6 volts.
Only thing different now is fire suppression system turned off, dialectric tank not hooked up, and no air hooked up (no tool changer or air chuck, so dunno why it would need air anyway), and a year has passed.
I booted up with the "system" disk and the "user data" disk and all seemed fine computer wise. There is a "install" disk that I didn't use...wonder if it needs that ? Paramenters seem to be in place.
