nlancaster
- Oct 8, 2018
Trying to learn more about taper machining.
I try to run the code that should according to the book work and I get an error that isn't in the book.
"Please cancel offset and/or taper, block 82 : M02;"
Now the block m82/M02 is just the end of program command.
I have G42 and G74 at the top of the program
G42 = Wire Radius Compensation Right
G75 = 4AXIS ON
And at the end of the program I have G40 and G75
G40 = Wire Radius Compensation Cancel
G75 = 4AXIS OFF
I can use the exact same code without any of the above commands, but that depends on mastercam to set the wire offset, not the best.
Any tips would be appreciated.
Here is the code:
G75 = 4AXIS ON
G75 = 4AXIS OFF
Here is the code:
Code:
(ALIGNMENT CHECK RING)
( 1 PASS OPEN )
( ON OFF IP HRP MAO SV V SF C PIK CTRL WK WT WS WP PC SK);
C000 = 008 015 2215 000 270 +050.0 8.0 0031 0 000 0000 025 180 080 040 0000 00;
C001 = 013 015 2215 000 240 +045.0 8.0 0031 0 000 0000 025 180 099 045 0000 00;
H000 = + 00000.00039 (Approch) ;
H001 = + 00000.00638 ( 1ST ) ;
H999 = + 00000.00200 ( Taper Offset ) ;
QAIC(2,1,0.00492,000.5,0.00610,0.00079,008.0,0004,0013,15,035);
SFCC00070015;
TP0.875
TN0.75
G90 G54
G00 M05 X0. Y0. Z-.125 U0. V0.
T91
G29
T82
T96
T85
G42
G74
C001 H001
G01 X-.00158 Y.01121 V-.0035
X-.00475 Y.03364 V-.0105
X-.02057 Y.14576 V-.04549
X-.0176 Y.15568 V-.0455
X-.01007 Y.16279 V-.0455
X0. Y.16517 V-.04549
X.03006 Y.16242 U-.00828 V-.04474
X.05911 Y.15423 U-.01628 V-.04248
X.0862 Y.1409 U-.02375 V-.03881
X.1104 Y.12286 U-.03041 V-.03384
X.13091 Y.10072 U-.03606 V-.02774
X.14706 Y.07521 U-.04051 V-.02072
X.15829 Y.04719 U-.0436 V-.013
X.16423 Y.0176 U-.04523 V-.00485
X.16469 Y-.01258 U-.04536 V.00346
X.15965 Y-.04234 U-.04397 V.01166
X.14928 Y-.07069 U-.04112 V.01947
X.13392 Y-.09668 U-.03689 V.02663
X.11409 Y-.11944 U-.03142 V.0329
X.09045 Y-.13821 U-.02491 V.03807
X.06379 Y-.15236 U-.01757 V.04197
X.035 Y-.16142 U-.00964 V.04446
X.00504 Y-.1651 U-.00139 V.04548
X-.02509 Y-.16326 U.00691 V.04497
X-.05438 Y-.15596 U.01498 V.04296
X-.08186 Y-.14346 U.02255 V.03951
X-.1066 Y-.12617 U.02936 V.03475
X-.12778 Y-.10466 U.0352 V.02883
X-.14469 Y-.07966 U.03985 V.02194
X-.15677 Y-.052 U.04318 V.01432
X-.16362 Y-.0226 U.04507 V.00623
X-.165 Y.00755 U.04545 V-.00208
X-.16087 Y.03746 U.04431 V-.01032
X-.15137 Y.06611 U.0417 V-.01821
X-.13681 Y.09255 U.03768 V-.02549
X-.11768 Y.1159 U.03241 V-.03192
X-.09462 Y.13538 U.02606 V-.03729
X-.06841 Y.15034 U.01885 V-.04141
X-.0399 Y.16028 U.01099 V-.04415
X-.01007 Y.16487 U.00277 V-.04542
X.01007 Y.16279 V-.0455
X.0176 Y.15568 V-.0455
X.02057 Y.14576 V-.04549
X.00241 Y.00776 V-.00607
X.00101 Y-.00286 V-.00303
X-.00039 Y-.01348
G40
G75
T85
T83
T97
T90
C777
M02
