tlmkr38
- Sep 27, 2008
- Dresden, Tn
having a problem cutting tapers on this machine. New to it all and am learning but... I cut one on a test piece one time but it didn't cut like I wanted. As in it set the taper on the first move which was one I needed the taper to be set before cutting it. I've since learned how to go about that but now the only way I can get it to cut one is on Mode 10 with me programming the U,V. The last one I used Mode 1 and just added a G52 Code and it worked but now I'm getting a Error 40 code which is programming I think.
Gonna post pictures of my program and the settings and ask if someone will look at it and tell me what I have wrong. I'm sure it is something simple but I'm just not finding it. I've got the books and from what I can see it is written right and the taper info is correct.
