tiny start holes and trodes for them
Hi TMD:
The most successful way I've found is to discharge dress the trodes to get them round and running concentrically.
Copper tungsten is the trode material most commonly recommended for these tiny holes...the way to get them to dress well is to pick parameters for the burn so the trode wears aggressively... so reverse polarity, high capacitance, high frequency etc etc: all the things you'd normally try to avoid with sinker work.
Your dressing block can be tungsten or copper tungsten...make it reasonably long and program the trode to traverse past the face as it's dressing.
Another way, if you have a rotary axis on your wire EDM is to turn and burn them...this is how Makino does it on their super high end small hole EDM.
The biggest problem you'll have is flushing...the aspect ratio of these holes is equivalent to a 5/16" hole through an inch of material...doable but not easy to get the flushing into the bottom of the hole.
You may actually find you have better success with a blade trode: you can direct a jet along the length of it and jump flush to keep it clean.
Tungsten copper wires beautifully so making the trodes becomes pretty straightforward for you with your setup.
They'll be a lot stronger and easier to handle than 0.002" wire trodes and they'll tolerate a lot more power too so they might even go a good bit faster than round trodes...the biggest drawback is you obviously can't rotate them to keep the dielectric circulating.
Another possible strategy to help get flushing into the hole is to use a round trode almost like you'd ramp a slot into a part with a milling cutter...program a zigzag ramp into the part with a spinning trode, making some room for you to get flushing down into the hole.
All these options are worth trying if you find you're having problems just sinking straight down with a 0.002" round trode.
Let us know how it goes
Cheers
Marcus
Implant Mechanix – Design & Innovation - home
