Wire EDM Tooling System is a modular tool system for Wire EDM. Free your valuable WEDM center from tedious settings, preset time, EROWA's Wire EDM tool system will help you and generate higher profits from your investment.
The right choice: the scalable EROWA Wire EDM tool system.
The Wire EDM Tooling System machine remains in production. The setting is carried out in the best environment without any operating time pressure. The processing time is greatly reduced because no settings are required on the machine. Loading robots-for more machines. It runs by itself at night and on weekends. Use a movable stand in a reasonable place. The thread in the EDM wire passes through a special groove. Use stop pins for accurate positioning.
