Hi again CountryBoy19:
I am presuming that my sniffy dismissal of 3D printed gears for your application are the bits you don't agree with, and I understand how you could think that way if you've been exposed to anyone who has claimed success with transposing gears made like that.
In the very short term, with a hobby application, you might get away with it for a time, and if the gear train is used infrequently and on small threads it might even be for a long time.
However, if you're running the lathe to make money and you strip the teeth in the middle of a high value part you will not be a happy puppy.
Similarly, if you expect to make precision threads on your lathe, the precision of all the elements of the gear train helps you, and although adama makes the point that a nylon gear faked on the rotary table is good enough for his needs and the transposing errors are small, there's still a good counterpoint to be made about eliminating or reducing those errors where possible.
If that is truly the case for YOUR needs too, then a Cheapo B&S style involute cutter and a rotary table are a better solution in my opinion than a 3D printed gear, simply because of the better physical properties of the milled gear, but I would choose Delrin over Nylon for its better strength and better dimensional stability in conditions of varying humidity.
Nylon is hygroscopic to a much greater extent than Delrin is, so you may find the backlash in your gear changes over time with a nylon gear, especially a large diameter one.
Also if the nylon gear does not remain round as it absorbs water, you will have an additional problem maintaining proper mesh between the gears
If you can't find what you're looking for in a B&S cutter, you can fake one, and to do so, Ivan Law's book on gear cutting will help you, so I encourage you to get a copy and read it.
It's intended for the hobbyist and it's a great resource I use a lot for prototyping.
A last point;
It is not possible to hob a gear with a standard hob on a Bridgeport with a standard dividing head or rotary table.
The hobbing process requires the gear blank to rotate synchronously with the hob, and the hob to be presented to the blank such that the helix angle of the hob is parallel to the axis of the blank.(a hob has teeth arranged in the form of a thread with gashes along its length to create cutting edges, so it has a helix angle)
It is however, possible to invoke a variant of the Sunderland gear generating process in which the involute profile is faked using a stacked array of cutting teeth arranged like the teeth on a properly mating rack, and the blank is indexed tooth by tooth as it would be using the B&S cutters, but the tooth form of the cutter is simple (straight sided rack rather than involute) so you can make it at home.
A gazillion Youtube videos exist showing this process and many believe incorrectly that it's a hobbing process but it's not.
So take all of this for what it's worth...free advice over the internet.
The main point however with respect to your original inquiry, is that a long cut path on the wire EDM is going to be an expensive proposition, and when the path is broken up into many small segments with corners, the wire slows down a LOT, so this seemingly obvious way forward gets to be an expensive deal killer very quickly.
Given where you're coming from and to satisfy your needs, I'd abandon the wire EDM idea and focus on the alternatives available to you but I stand by my contention that a 3D printed gear is a crappy solution for anything other than the most casual hobby use and even then, it's a point of vulnerability to disaster easily overcome with better methods.
Cheers
Marcus
