J
Johnny Larue
Guest
so I might be the only one in America that runs a MV2400S ADVANCE TYPE 2 wire edm that's for Europe and has the safety crap...but I took off the European software and loaded the American version instead and disabled the auto manual key turn lock....so its slightly different...but it should be the same in M codes and programming but not might be...you guys overseas do you have one still in Europe software mode.....I was wondering how to turn off the water automatically....you know you can M122 and raise the door and fill tank auto and start job...then it gets done...you shut off cutting by M91 adaptive control off and then...do I add before or after this code....I want to drain the tank and have the water off so it don't spray or have to be turned off manually before draining or it squirts all over if your not there...what codes you guys using and in what order...I cannot get the fluid off and then lower door...the door will lower but fluid still on no matter what...tried M33 and then M58....M75....M77.....M81....M88 and M89....nothing...all works except fluid stays on....do you use the auto manual key turn lock at top of control panel if your still in european mode...have you changed yours to american if you have one...wondering if it might be our machine since it was the first one made I believe...we have a MV2400R regular...this is a MV2400S advance type 2...and have a good holiday if you celebrate one...thanx in advance if anyone knows this...later
