Wire EDM barreling
Results 1 to 7 of 7
    Jan 2020
    North Carolina
    Default Wire EDM barreling
    Looking for information on how to reduce the barreling effect while cutting with wire EDM.
    Aug 2006
    greensboro,northcarolina
    2,389
    150
    585
    Wire tension correct? Wire speed? What height and what tolerance are you trying to achieve? How may passes are you using, what size wire? They all will have an effect.
  3. Likes Zahnrad Kopf liked this post
    Apr 2008
    Auburn Hills, MI
    246
    37
    58
    dschrech,
    Is this the type or error you are seeing? Please see the attached picture.
    Aug 2010
    New England
    278
    32
    What machine? part material? part thickness? wire? how much error? number of passes?
    Jan 2020
    North Carolina
    Great questions. Bosses have yet to invest in a way to measure tension. How does speed affect it? I cut a variety of material heights. Tolerances are tight...+/- .0003. Thanks.
    May 2011
    New Jersey
    2,287
    202
    1255
    Machine:
    Material:
    Wire size:
    Sep 2005
    Dunstable, UK
    32
    18
    Quote Originally Posted by dschreck View Post
    You absolutely need a wire tension gauge!!! For +/- .0003 you will need a rough plus at least 2 finish passes.
    Tony
