Wire EDM Di water system
Results 1 to 4 of 4
    May 2021
    Delaware
    18
    Default Wire EDM Di water system
    Guys,
    Take a look at the attached picture of my Di water set up on my wire EDM machine. To summarize;
    -the city water enters the system via the copper pipe on the right
    -there is a filter to catch any sediment that may be present, there is a pressure gauge prior to the sediment filter
    -after it exits the sediment filter, the water flows into the first tank via Tygon hose which is equipped with a sight gauge/strainer.
    -exits the second tank, and continues to the machine.
    The issue being, that when the machine is in need of water, I like to fill it thru the Di tanks, but they seem to not have adequate flow thru them...as if they are clogged. So I get impatient, and fill the machine; that sends the resistivity crashing, thus the machine acts goofy until it reaches its happy place.
    Would I be better off running the tanks in parallel versus in a series as such as the current set up (I just thought of this as I was typing)? Does anyone else have these issues?
    Thanks for the input,
    Mark
    May 2011
    New Jersey
    2,942
    290
    1617
    I usually just fill off the bottle on the machine.
    Jun 2013
    Ohio
    35
    17
    9
    My $.02?
    Top off your tank(s) every morning. That way it never takes too long.
    Dan
    May 2021
    5
    Quote Originally Posted by M. Roberts View Post
    Guys,
    Mark
    I have an extra bottle on a water line I only use for filling the tank.
  5. Likes OffsetLeft, pb1 liked this post
