Triggerman
- Mar 24, 2020
I'm building wire EDM in my school as a thesis. Can anyone tell me what kind of pressure and flow rate is normal in wire edms flushing water pumps. Perhaps if you have wire edm you could just give me the specs in the water pump. Also approximately how thick water tubing is usually used. Max cutting height will be 100mm
