Chris,
your machine should be able to do up to 4 skim passes. The last pass should be a PIKA pass that will give a great finish and extreme accuracy. To do accurate 4 axis cuts there should be a program on your hard drive called 'LNTPRDAT" that you run in conjunction with the your wire aligning device. This will set your table to lower and table to upper settings. Instructions are in the program. Below is the 4 axis program you asked for. You will need to change the header and create one with your machine settings for a 5 pass water tech.
( Search Data : ,Water,D0.010mm,Brass,Steel,H0.39mm,Die,Open-U,2.6,3orMore );
( ON OFF IP HRP MAO SV V SF C PIK CTRL WK WT WS WP PC SK BSA );
C000 = 012 015 2215 000 242 +025.0 8.0 0059 0 000 0000 025 160 098 045 000000 000000 200100;
C001 = 002 009 2215 000 000 +044.0 5.0 1026 0 000 0000 025 180 098 240 000000 000000 310000;
C002 = 001 014 2210 000 000 +053.3 2.0 1020 0 000 0000 025 180 098 240 000000 000000 410000;
C003 = 014 020 0504 000 000 +044.2 6.0 1020 0 000 0000 025 180 098 240 000000 000000 510000;
C904 = 100 000 0001 000 000 +046.9 0.0 9055 0 045 0000 025 180 098 240 000102 000006 610000;
H000 = +000000.000390;
H001 = +000000.009070;
H002 = +000000.006320;
H003 = +000000.005650;
H004 = +000000.005370;
H005 = +000000.005060;
TP0.0;
TN2.0;
G90;
G92 X0.0 Y0.0 U0.0 V0.0;
CSP00100000022;
TT2.0;
TB0.0;
QAIC(2,1,0.00492,000.3,0.00630,0.00039,004.0,0020,0029,15,035);
G29;
(SolidWire - 4 Axis Contour : Sodick);
T94 (Water dielectric);
T84 (Pump ON);
(ROUGH PRIMARY CUT);
C000;
G141 H000;
G01 X0.0005 Y0.0 : G01 X0.0005 Y0.0;
G01 X0.25 Y0.0 : G01 X0.5 Y0.0;
H001;
G01 X0.25 Y0.25 : G03 X0.35355 Y0.35355 I-0.5 J0.0;
G01 X0.0 Y0.25 : G03 X0.0 Y0.5 I-0.35355 J-0.35355;
G01 X-0.25 Y0.25 : G03 X-0.35355 Y0.35355 I0.0 J-0.5;
G01 X-0.25 Y0.0 : G03 X-0.5 Y0.0 I0.35355 J-0.35355;
G01 X-0.25 Y-0.25 : G03 X-0.35355 Y-0.35355 I0.5 J0.0;
G01 X0.0 Y-0.25 : G03 X0.0 Y-0.5 I0.35355 J0.35355;
G01 X0.25 Y-0.25 : G03 X0.35355 Y-0.35355 I0.0 J0.5;
G01 X0.25 Y-0.02 : G03 X0.49901 Y-0.0314 I-0.35355 J0.35355;
M00;
G01 X0.25 Y0.0 : G03 X0.5 Y0.0 I-0.49901 J0.0314;
H000;
H000;
G140 G01 X0.0 Y0.0;
T85 (Pump OFF);
(SKIM PRIMARY CUT [ 1]);
C001;
G142 H000;
H002;
G01 X0.25 Y-0.25 : G02 X0.35355 Y-0.35355 I-0.5 J0.0;
G01 X0.0 Y-0.25 : G02 X0.0 Y-0.5 I-0.35355 J0.35355;
G01 X-0.25 Y-0.25 : G02 X-0.35355 Y-0.35355 I0.0 J0.5;
G01 X-0.25 Y0.0 : G02 X-0.5 Y0.0 I0.35355 J0.35355;
G01 X-0.25 Y0.25 : G02 X-0.35355 Y0.35355 I0.5 J0.0;
G01 X0.0 Y0.25 : G02 X0.0 Y0.5 I0.35355 J-0.35355;
G01 X0.25 Y0.25 : G02 X0.35355 Y0.35355 I0.0 J-0.5;
G01 X0.25 Y0.0 : G02 X0.5 Y0.0 I-0.35355 J-0.35355;
H000;
H000;
G140 G01 X0.0 Y0.0;
(SKIM PRIMARY CUT [ 2]);
C002;
G141 H000;
H003;
G01 X0.25 Y0.0 : G03 X0.5 Y0.0 I-0.35355 J0.35355;
H000;
H000;
G140 G01 X0.0 Y0.0;
(SKIM PRIMARY CUT [ 3]);
C003;
G142 H000;
H004;
H000;
H000;
G140 G01 X0.0 Y0.0;
(SKIM PRIMARY CUT [ 4]);
C904;
G141 H000;
H005;
H000;
H000;
G140 G01 X0.0 Y0.0;
G149 G249;
M02;
