1" dia SS pipe bends - how/where to buy - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Nov 2007
    marysville ohio
    9,862
    2819
    6574
    Quote Originally Posted by ezduzit View Post
    Any source for these in polished stainless?
    Tube Techniques can do them in polished ss as well. phone number in post 18.
  2. Likes ezduzit liked this post
  3. #22
    May 2002
    South Central PA
    13,886
    2432
    3674
  4. Likes DrHook liked this post
  5. #23
    Jun 2013
    317
    152
    132
    Thanks fellas.
  6. #24
    Jan 2005
    Houston
    6,240
    786
    3005
    Here are 4 of the handles 'in process' but it shows what they look like. The bend is 'hard part' #1, hard part #2 is machining a 45 deg V into the small bolt pads.
    The goal with this whole cost-reducing exercise is pretty common - make them cheap enough that people look at them and say, "I could make those. But I won't bother...."
  7. Likes DrHook liked this post
  8. #25
    Oct 2009
    Oregon
    4,871
    5268
    2511
    Make from solid in a press brake?- Bam, one hit done?
    Make from smaller diameter tube (3/4) easily with a handbender and after powdercoating slide a piece of silicone hose over the tube to make a nice grip and bring to comfy size?
    Make from 3/4" solid in press brake and do same as above?
  9. Likes GregSY liked this post
  10. #26
    Jan 2005
    Houston
    6,240
    786
    3005
    The finished handles have grips, aka bicycle grips. The 1" diameter it only a bit larger than the standard handlebar so the grips fit well. I ordered some Woolf bends (4) to see if I like them. Still a bit pricy...$50 for 4 plus 'mystery' shipping charge.
  11. #27
    Nov 2019
    CANADA
    Ontario
    83
    17
    11
    Quote Originally Posted by GregSY View Post
    why not just have someone bend those tubes?
    sure it would need to be mandrel bent, but that would be a hell of alot easier then grinding smooth.
    or get a normal bender and fill/cap the tubes with ice or sand. trim to length and done.
    or if its just a handle, skip all the bending, weld a piece of 1"flat stock to set the height onto to a straight tube. done.
