1980 Miller Dial Arc 250, Tripping Breaker At Start Up!!!
Results 1 to 9 of 9
    May 2005
    Central Fla. USA
    250
    93
    25
    Default 1980 Miller Dial Arc 250, Tripping Breaker At Start Up!!!
    Hi,
    Tried to use my Miller today and it's tripping out on start up.
    It is also making a hum, it never did before at start up then trips the 50 amp breaker.
    Never had this problem before, also the cord to the outlet and the breaker are fine with my Mig 180, so...
    I'm thinking I have a Welder problem?
    Does anyone here have any ideas on this?
    This Welder is a Beast and not looking forward to taking it to a shop, rather fix it myself, if possible!
    Thanks!!!
    Oct 2005
    22,083
    I'll wager you blew a diode in the output section.....
  3. Likes BT Fabrication liked this post
    May 2005
    Central Fla. USA
    250
    93
    25
    Hi,
    Thanks, is there a troubleshooting procedure to see if that is it?
    Oct 2005
    22,083
    Quote Originally Posted by seagiant View Post
    Hi,
    Pull up the schematic, and post it here.
    May 2005
    Central Fla. USA
    250
    93
    25
    Hi,
    This was all I could find, the Welder is a little old.
    This at least shows where the diodes are and I do know how to test with my Fluke.
    The Ser.# is JB538078, it is not an HF model, just AC/DC.
    Thanks!
    https://www.millerwelds.com/files/ow.../O314G_MIL.pdf
  7. Likes digger doug liked this post
  8. #6
    Oct 2005
    22,083
    Hi,
    Thanks!
    That's perfect.
    Someone will be along shortly to walk you thru the test.
  9. Likes seagiant liked this post
  10. #7
    May 2005
    Central Fla. USA
    250
    93
    25
    Hi,
    "Thanks" everyone, found help on the Welding Web.
    Doug, PM inbound!
  11. #8
    May 2005
    Interior British Columbia
    2,754
    318
    925
    I had great luck there as well, with two different Miller Welders.
  12. Likes seagiant liked this post
  13. #9
    May 2005
    Central Fla. USA
    250
    93
    25
    Hi,
    My trouble was a Diode, and I replaced all 4 at one time.
    Welder is back humming along...
    That big Miller, will burn a rod!
