3/4 HP Bridgeport electrical question
Results 1 to 5 of 5
    Dec 2013
    New York
    80
    46
    Default 3/4 HP Bridgeport electrical question
    Do you know if this Bridgeport is single phase or 3 phase? The motor says single but the plug looks like it's 3 phase. There's no vfd or anything on it, just a junction box to the power feed. I read that Bridgeport made some 3/4 HP models that were single phase. I was thinking this was one of them, but the plug threw me off. I will post photos below. I think the plug is a Non-NEMA Four-Blade Turn-Lock Connector, Non-Grounded, 120V AC/208V AC, 20A
    Feb 2013
    Northern califorina, usa
    417
    9
    153
    It's anyone's guess about the twist lock plug, the motor is clearly 220 Volt, single phase.
    On single phase applications some times 4 pole plugs are used. two legs are hot 120/120, one leg is common and the 4th ground.
    If there was a work light or a readout on the machine that was 120volt then there would need to be a common leg to complete that circuit. the ground of course for safety.
  3. Likes j c, michiganbuck liked this post
    Dec 2013
    New York
    80
    46
    Thanks a lot. Yeah, there's a power feed, so that must be for the common. I took off that plug and put on a NEMA L14-30 plug and it's working well now off the single phase. The original 1960s power feed works perfectly too which is great.
    May 2006
    Seattle
    2,547
    65
    667
    Is that machine fitted with a reversing switch?
    Dec 2013
    New York
    80
    46
    Quote Originally Posted by metalmagpie View Post
    Yes it has a reversing switch on the top left. I haven't used reverse yet but I tried it and it works. My powerfeed just seemed to stop working today though, not sure why. The motor runs but it wont engage.
