rons
- Mar 5, 2009
- California, USA
Some door knob brass with antique finish has chipped off/worn off. Outside it's the UV and temp difference. Maybe the thousands of hand jobs
contributes too. There is always uneven wear depending on whether you are right or left handed. Outside the temp difference can be 32 - 95 in
not so sunny Kalifornia.
So I made a few dowels with the right diameter to hold the door knobs, spun them up and gave them a brushed finish with some gray scotch brite.
Eventually the brass gets dark and looks antique again but with a dull look. But not like the original. So isn't that what antique brass is. Aged looking
The original Schlage finish looked like it was brushed (circular lines). It was tough to remove like a powder coat job. The old finish didn't budge with
something like lacquer thinner or paint remover. But the old finish was sealed and always looked shinny.
Bottom Line:
Is there a wipe-on/or dip solution for brass to seal it? Is PPG clear the way to go on a brushed surface just of the lathe?
A brushed finish like on a refrigerator door is the best finish in my opinion.
Bottom Line:
