jeremyb1
- Aug 13, 2012
- USA, Connecticut
For the last year or so I’ve been making jigs for one-off electronic test probes that we use internally. I’ve been using Delrin 150 FG (for no particular reason other than its easy to machine and non-conductive) without issue on small jigs, but it seems like anything over two square inches and the Delrin starts to bend if I pocket more than 1mm from a 1/4" sheet.
I’m using a vacuum table, a spindle speed of ~24K and a feed rate of 800mm/sec (tried slower and it didn’t seem to make a difference), I’m also doing Z-Axis Measurements (ie: warping) on my g-code so everything is as close to spec as possible.
Workarounds I’ve come up with are stacking thinner stock (eg: 1/8” sheets, they still bend but are more malleable), creating holes and plugs on two different 1/4” layers to lock the Delrin in place (PITA to get it right). None of these are anywhere near what I’d call good solutions.
So I thought I’d ask the pro’s if they recommend a different material, different process, etc?
