Bending 3/4 x 2 stainless flat bar the easy way
Results 1 to 7 of 7
    Oct 2014
    Maine
    628
    24
    295
    Default Bending 3/4 x 2 stainless flat bar the easy way
    I may need to bend some 3/4 x 2 flat bar into a U shape with 2" inside dimension. Material is 316 stainless.
    I've been thinking about getting a Hossfeld or JD2 bender for another bunch of projects, but I think this is too big for either of those. I do have a 70-ton H-frame press if that's useful, or I can send it out, or I can just machine it from solid. Quantity is 5 to 10.
    May 2014
    Hollister, Calif
    21
    6
    Or you can cut and weld the pieces. How long are the legs measured from the inside?
    Oct 2014
    Maine
    628
    24
    295
    3.5" ish
    welding might be an option. I'll have to check the stresses.
    Aug 2012
    California, Central Coast
    1,453
    1665
    423
    If you could heat it dull red the hossfeld should do it. The 316 may need to be passivated after. The edges will deform a bit if that matters.
    Jul 2013
    California, USA
    525
    581
    575
    Check out this handy dandy press brake tonnage calculator.
    Press Brake Tonnage Calculator — Cincinnati Incorporated
    May 2014
    Hollister, Calif
    21
    6
    With your press you should be able to do it . I keep these chain links around for bending U shaped pieces. Also in the other photo a adjustable frame and shop built punches.
    A lot of spring back with SS. If you need 2" in the your punch should be maybe 1-3/4".
    I'm guessing there could be smaller.
    Sent from my SM-G950U using Tapatalk
    Oct 2014
    Maine
    628
    24
    295
    Quote Originally Posted by NVelho View Post
    Thanks for the pictures, that makes a lot of sense.
