Bending brake disassembly/reassembly?
Results 1 to 2 of 2
    Sep 2010
    Guinea-Bissau, West Africa
    744
    133
    Default Bending brake disassembly/reassembly?
    Does anyone have any experience with taking a bending brake apart? I'm looking for an 8' apron brake (~16ga) to ship as part of a C container to West Africa, and it takes up a lot of space, but a lot of it is air space. I think taking apart a stomp shear ends up creating a lot of fiddly work getting it all back into alignment, but would reassembling an apron brake (with a gantry handy for lifting) be any great wizardry?
    Thanks!
    Feb 2014
    Cartersville, Ga
    256
    81
    138
    Quote Originally Posted by JasonPAtkins View Post
    Thanks!
    I've taken one apart enough to replace bushings. Methinks your only worthwhile space savings are to remove the counterweight arms and maybe the legs. Most else is reasonably dense.
    If you do end up taking it further apart (maybe the leaf gets removed, I can't see taking off the top apron helping), it's not incredibly hard to realign everything, and knowing how to do all of the aligning is instrumental in getting accuracy out of one, even if it hadn't been disassembled, so you're not exactly hurting yourself by learning to realign everything.
  3. Likes jamscal liked this post
