Bending Machine Fabrication
Results 1 to 10 of 10
    May 2013
    Chennai,TamilNadu,India
    11
    Question Bending Machine Fabrication
    Dear All,
    I am in to manufacturing Foundation Bolts and as it requires bending the bolts i have fabricated a hydraulic bending machine using a 50 ton hydraulic jack..i want to know of what material should i make the dies for bending as while bending the dies are getting damaged alot and also if anyone can help me with how to fabricated the table or dies for bending a J Type Bolt
    Jun 2010
    milton freewater oregon
    2,029
    3811
    1643
    Iv made lots of j bolts and use a simple machine like this.
    So simple a monkey can run one. We don't have monkeys in this part of the world though. Wish we did.
    Tube Bending Machines | Metal Benders & Bending Dies | Hossfeld UNIVERSAL™ Bender, Winona, MN
    Oct 2013
    Russia Rostov-on-Don
    7
    23
    Quote Originally Posted by fakhruddinhaji View Post
    Dear All,
    could you show us a drawing?
    Mar 2021
    SERBIA
    Hi guys!
    Maybe this machine will help you with bending the sheet metal:
    https://dinamicline.com
    Machine specifications:
    Type: CNC
    Length: 8000mm
    Width: 1300mm
    Space requirements: (1900 x 1650 x 8800)
    Metal sheet bending thickness: 0.7mm
    Bending angle: 136 stepeni
    Machine weight: 3t
    Power requirements: 3kw/16A
    Motor power: 2,2 kw
    Opening width: 105mm
    Insertion depth: 1250mm
    Hope this will help!
    Sep 2017
    South Carolina
    878
    645
    665
    Quote Originally Posted by mikola_p View Post
    Can you not picture something as simple as a "J" in your head?
  6. Likes dkmc liked this post
    Sep 2017
    South Carolina
    878
    645
    665
    Quote Originally Posted by skee11 View Post
    Hi guys!
    Type: CNC
    Length: 8000mm
    Width: 1300mm
    Machine weight: 3t
    Motor power: 2,2 kw
    A "J" bolt made of sheet metal? Why haven't I thought of that? After all, it's only for a foundation.
  8. Likes dkmc liked this post
  9. #7
    Sep 2004
    Wisconsin
    247
    61
    +1 on the Hossfeld type bender. J shape not required, 90 degree bend will do. No die needed. Bend between 3 round pins spaced for no crack radius.
  10. #8
    Jan 2006
    Brookfield, Wisconsin
    4,295
    300
    431
    Thread was created almost 7.5 years ago.
  11. Likes dkmc, BT Fabrication liked this post
  12. #9
    Jan 2016
    New York
    295
    6
    81
    Default Forming Die Tool Steel for wear
    Use D2 high carbon high chrome tool steel heat-treated to 62-64Rc for the P&D. A simple "V" Shape. Make the punch bend radius the same as the form radius of the bolt. Use a one inch thick steel plate for mounting your dies and jack in a horizontal position. Make the form blocks thick enough to run (3) parts at a time (1 1/2"-2" thick). 3/8" screw and dowel the die solid to the plate. Make guide rails on each side of the punch to hold the slide to base-plate so the punch maintains alignment with the die. One thing you didn't mention is the annual requirement. Use oil to run the parts. If your planning to supply the industry, consider using a hydraulic cylinder and hydraulic pump with two button hand controls.
    Roger
  13. #10
    Oct 2017
    1,305
    414
    442
    Quote Originally Posted by crazygoat View Post
    The bend radius, angle, flange length (if you call it that on round stock), distance to threads, and diameter are all very critical to selecting a die.
    Yes, you could type all of those out, but that's also the exact information the drawing contains.
