Best gas for welding
Results 1 to 12 of 12
    May 2019
    INDIA
    5
    Default Best gas for welding
    Hi...
    I am running a workshop for the past 6 months. I have a doubt that which gas is perfect for Dig welding?
    May 2011
    New Jersey
    1,800
    166
    977
    Did you possibly mean mig or Tig?
    Jan 2019
    Tennessee
    343
    92
    94
    parent material and filler?
    Oct 2005
    14,005
    Acetylene works best.
    Try cracking a book...amazing things they are.
  5. Likes Newman109 liked this post
    Oct 2005
    Wilmington DE USA
    1,977
    302
    407
    For dig welding.... as shovel
    But more info will be required evan if you meant tig
    Apr 2004
    Modesto, CA USA
    6,584
    1071
    Gasoline fueled blowtorches use white gas not automotive fuel. This is what is commonly used in Coleman camping products. About $8.00 a gallon at Walmart for the house brand. I believe it is mostly naptha. I use it to thin oil based paint.
    The gas blowtorches are really only used to preheat metal prior to welding or to heat tools for soldering big sheets of metal as in roofing. They are too big a flame for welding and not high enough a temeperature to melt metal other then solder.
    Bill D.
    Oct 2005
    14,005
    Good Ole H20 ...From the Ganges would be best:
    Multiplaz. Welding, Cutting, Soldering, Brazing...
  9. #8
    Jan 2006
    Angier, North Carolina
    2,542
    1012
    913
    lincy, welcome to the forum. This place has an enormous wealth of information to share, but as you can see, it also tends to be impatient when someone asks a broad question but provides limited data.
    As others have said, give us some background on what you are welding, which process(es), what sort of equipment.
  10. #9
    Oct 2018
    Arizona
    8
    DIG setting is a STICK weld setting only. No external shielding gas is used.
  11. #10
    May 2019
    INDIA
    5
    Thank you for your valuable replies.
  12. Likes Demon73 liked this post
  13. #11
    Oct 2005
    14,005
    Quote Originally Posted by lincy View Post
    GIGO
    "Garbage In Garbage Out"
  14. #12
    Aug 2015
    Illinois
    1,317
    943
    554
    Quote Originally Posted by spiceman View Post
    I believe it refers to the amount of inductance in the circuit. Some modern "suitcase" welders allow inductance control on Mig as well as on stick.
