Best Tig rod for A2,S7 and D2 Mat.
Results 1 to 17 of 17
    Nov 2020
    Tennessee
    Default Best Tig rod for A2,S7 and D2 Mat.
    We have a trim block that we have been making with a vertical cutting edge . We have made it out of all 3 material. We normal us a 72,74 or 1216 rod to repair trim edge. After several hundred stroke it starts breaking down. Looking for something new to try.
    Nov 2014
    Missouri
    332
    164
    132
    Maybe 1215?
    The the ones you listed are for H12, S7, and M2. None really ideal for a trim blade IMO. (Thinking of die cast aluminum parts here - if you are doing some kind of hot work that may be different)
    Tool Steels
  3. Likes Matt_Maguire liked this post
    Nov 2020
    Tennessee
    We do metal stamping . This is a tool steel block. The material type that we are trimming is 251-540p
    Nov 2014
    Missouri
    332
    164
    132
    It was clear what your were welding on, just not what the die was intended to be used for.
    I'd still try the 1215.
    1216 is the same as high speed steel cutting tools, and probably too brittle. The others wont have as good of wear resistance.
    Weld repairs often wont last near as long as a new block no matter what.
  6. Likes BT Fabrication liked this post
  7. #5
    Nov 2014
    Missouri
    332
    164
    132
    If you have a large budget, and are looking for a really different approach, I've heard good things about laser & micro welding tool steels, but haven't witnessed it first hand.
    Laser Welding Versus Micro Welding |
    MoldMaking Technology
  8. #6
    Nov 2020
    Tennessee
    I agree on new block but those add up on cost over time lol. The vertical trim is what's getting us it just builds up and starts chipping the block then part starts cracking.
  9. #7
    Nov 2014
    Missouri
    332
    164
    132
    I'm not a stamping guy. Maybe someone else can recommend something to help with the buildup.
  10. #8
    Jan 2015
    Missouri
    1,410
    224
    915
    Every time you weld on them it pulls the carbon it just gets worse every time you work on them but it gets a guy out of a jam until details can be built
    Don
  11. #9
    Nov 2019
    CANADA
    Ontario
    583
    900
    138
    Quote Originally Posted by Hillside Fab View Post
    ya id be looking at the knife blade design. or a better lubricant.
  12. Likes ToolDie310 liked this post
  13. #10
    Mar 2005
    Kansas
    8,565
    590
    4308
    Are you doing any heat treatment after welding, or just using it as welded?
  14. #11
    Nov 2020
    Tennessee
    Yes we post heat .
  15. #12
    Jan 2016
    New York
    295
    6
    81
    Default I agree with looking at changing the tool design.
    Quote Originally Posted by BT Fabrication View Post
    Change the design so the blade can be a solid or screwed to a blade holder. I'm a diemaker, die designer in stamping dies; I'm not a welder. I taught tool and diemakers for several years in another life. Welding tool-steel can be done if the proper heat-treat is applied after welding. But welding tool steel should be avoided where ever possible. Otherwise the problems your having with the tool can continue to exist. A picture of your tooling would be helpful.
    Roger
  16. #13
    Apr 2021
    Every time you weld with welding rod it pulls the carbon it just gets worse every time you work on them but it gets a guy out of a jam until details can be built
  17. #14
    Apr 2021
    Quote Originally Posted by robertstevenbk View Post
    Maybe someone else can recommend something to help with the buildup welding rod
  18. #15
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,203
    1042
    775
    A company callled "Weld MOld" makes a lot of different rods for tool repair. I have fixed shear blades and bolt cutters with their stuff. Call them
  19. #16
    May 2021
    Florida
    Quote Originally Posted by magneticanomaly View Post
    Do you have a more specific address for that company? I am looking for the same.
  20. #17
    Nov 2010
    UNITED KINGDOM
    1,014
    201
    246
