black brazing flux
Likes Likes:  0
Results 1 to 10 of 10
    Dec 2016
    TAIWAN, PROVINCE OF CHINA
    194
    12
    Default black brazing flux
    Is it possible to make this stuff, what exactly is it made of?
    I tried to buy some stay-silv black flux but it must have a hazardous material classification because no one will ship the stuff. But I tried googling what exactly it contains and came up empty (trade secret?).
    I see guys in China selling the stuff and it looks like they mixed it themselves.
    I want to braze some carbide but the only flux available to me is borax (doesn't work), and white brazing paste (works, not sure of strength). I even tried borax just joining 2 pieces of steel, doesn't work either.
    Jul 2007
    UNITED KINGDOM
    4,715
    2482
    2289
    It's a boron based flux, but I'm not sure what the difference is between common-or-garden borax and stay-silv, other than there are fluorides in it as well.
    I bought a 1lb pot from Amazon, delivered from the US to the UK after I had difficulty in getting JM tenacity 6A in small quantities. It might be worth trying this route.
    Jun 2016
    New York
    1,456
    792
    618
    Quote Originally Posted by taiwanluthiers View Post
    if the white flux works, just use it. unless you are doing production, its not going to matter all that much. as long as you get a good flowing joint, the flux has no affect on the joint strength. the black flux is better on steel, and at higher temps, but if you do everything right, clean really well, use plenty of flux, heat quickly to temp, keep the joint in the reducing flame the entire time (easy with a carbide tool of reasonable size), you should be fine.
    Dec 2016
    194
    12
    I'm using a propane torch for this, and it takes a good minute or so to get it up to temp... I'm wondering if that caused some difficulties with borax.
    I'm not really wanting to use acetylene torch because oxygen is expensive and doesn't last all that long. I just wonder if acetylene air torch exists...
    Jan 2019
    56
    33
    33
    Interesting the the environmental laws are more strict in China
    Dec 2016
    194
    12
    It had something to do with the guy wanting to use SF express, and that SF express will NOT accept any powdered substance of any kind. And the guy will only use SF express, not anyone else (not sure why).
    I found a guy selling a pound pot of Stay Silv black flux... 10 dollars and only 31 to ship it to Taiwan through their global shipping program.
    Maybe I should look into an acetylene air torch or something too. Propane takes a good minute or 2 to heat the part to temp.
    Jun 2016
    New York
    1,456
    792
    618
    of course it does, a Smith, prest-o-lite or Lenox plumbers rig is air acetylene. MAPP is good too, hotter than propane. larger, brushier flame is good for brazing, thats what they are made for.
    don't use borax alone, I've done it, but why? use a proper flux made for brazing.
    Dec 2016
    194
    12
    I've seen someone sell a gasoline blowtorch... claiming it's a lot cheaper to maintain than acetylene. Any dangers to gasoline torch?
    Oct 2018
    Kansas
    Maybe try Peterson hi heat flux, it's really made for cast iron. Might try Sill floss.
    Good luck
    Aug 2003
    port allen, louisiana usa
    1,667
    446
    386
    Oxygen usually is used up pretty fast if you are cutting thick metal but for just brazing or welding it lasts a very long time unless you have leaks in your system somewhere.. Been using oxy acet torch for over 50 years in USA..Cheers; Ramsay 1
