jimmysgarage
Cast Iron
- Jul 22, 2008
- Portland Oregon
I just spent the past 20 hours brazing a bicycle frame with a good friend who has been brazing for nearly 20 years. He is used to his set up which includes a in-line gas fluxer with oxy and propane/mapp gas. (There's a questions here I'll come back to)... I have a oxy/acet setup with the same inline fluxer. We were brazing bicycle tubing (7/4/7 being the thinest) silver nickel and getting poor results. We could not get a good flow of the s/n and the tip of the torch kept getting dirty...? it would have a build-up of crud that would affect the flame, which also would slow down as if you were slowly turning the tanks off.
First, back to the top. The local weld shops tell me that: MAPP and Propane is the same gas....? I have been told different from others. I have also been told that you can not simply switch over to MAPP/Propane with a oxy/acet torch. That there is a difference in the torches/regulators and you have to purchase the correct ones for said fuel. My friend thinks otherwise....
Any ideas what went wrong? The fluxer is BRAND new, this is the first time I used it. I don't believe that is the issue... maybe not... Why would the tip of the torch get a build up of (lack of better term) crud on it...?
Any and all help welcome!!
Jimmy
Jimmy
