building a mig welder
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Sep 2019
    UNITED KINGDOM
    Default building a mig welder
    so ino this has prob been asked a million times
    but i have burned out about my 6th welder in a couple of years. so i want to build a heavy duty mig set to max out about 160-200amp
    i have bought a old external wire feed thats 42v ac to strip the feed motor out of.
    i have the parts coming to build a 500amp rectifier.
    now comes the transformer. i am looking at building a multi tap transformer.
    but i was thinking why not use a scr input voltage controller or something simple to control the input voltage.
    would make it a lot easyer to build and to repair. any ideas.
    thanks
    Dec 2008
    IL/WI border
    3,212
    1016
    937
    If it wasn't a joke, may I ask you what welders you used?
    Oct 2014
    Massachusetts
    75
    80
    52
    Quote Originally Posted by MichaelP View Post
    ditto, plus if I may add, what kind of work are you doing with it, how often, anything special about it? It's just that going through 6 welders in two years sounds pretty extreme.
    Oct 2005
    15,133
    How many microwave ovens have you amassed ?
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,155
    1019
    605
    #1 Quit buying the cheapest welders on Amazon
    #2 There are plenty of old transformer based mig welders available, cheaper than you can build one.
  6. Likes Newman109 liked this post
    Sep 2019
    UNITED KINGDOM
    i had a snapon 130, snapon170, the snapon welders i had where the worst the wirefeeds are trash. wolf140, miller180, lincoln 160,
    just bought a 200 igbt felt like a 120 amp welder and shit it self.
    i have a 240v supply no 3 phase.
    welding 6mm steel most of the time.
    Feb 2011
    1,155
    1019
    605
    Look for something that requires a forklift to lift, they made them in 240v single phase (US), not sure about the miller180 or lincoln160, but the rest of those you mentioned are little cracker box welders, great for light duty and portable, but not for serious welding.
  9. #8
    Jan 2019
    Tennessee
    467
    145
    121
    an alternator for power, starter for feed...
    I say making a welder would be fun for someone obsessed about the theoretical process, not someone who wants 'heavy duty' 200 amp welder cheap.
  10. #9
    Oct 2005
    15,133
    Quote Originally Posted by xadmx View Post
    6mm = .24 inch thick ?
    What process ?
    What duty cycle ?
    Only 200 amp ?
    What's "Failing" ?
  11. #10
    Oct 2004
    Iowa
    3,153
    66
    399
    If you're killing that many welders in that short a time, you're doing at least more than one thing wrong.
    Yes, first off, they're not industrial-grade machines, second, they're certainly not capable of their 'advertised' output for any great length of time. Ignore all ratings unless they say 100% Duty Cycle.
    Next... the common failures for welders, particularly cheap portable homeowner big-box/tool-truck stuff, is failed diodes, and usually, snubber capacitors for the diodes, if they even have 'em... most don't.
    I realize that your circumstances in the UK aren't like say... Ohio... so you won't find loads of serious industrial 300A MIG supplies around, but yes, if it requires a forklift or six strong men to heft it out of your lorry, then you've got the right thing.
    The lack of 3ph is irrelevant, there's lots of solutions to that problem, many 3ph welders can be converted to run on single with 100% output, and those that cannot can be run off a homemade rotary converter.
    You need serious iron, with serious copper windings.
  12. Likes Ifitsmetal liked this post
  13. #11
    Apr 2005
    Brandon, MS
    818
    114
    168
    Agree with the others. If you're welding 6mm stuff every day, you need to step up to a 250 series MIG welder.
    You've been frying what you've been running because they're not made to run as much as you need to.
  14. Likes Gustav129 liked this post
  15. #12
    Sep 2006
    Sacramento County, California
    3,717
    2349
    1267
    With welders such Lincoln and Miller available at discounted prices all of the time, I wouldn't dream of building my own
  16. #13
    Feb 2011
    1,155
    1019
    605
    I had a small welding job a few months ago, and only welder available was the cracker box mig. Probably did not help that it was already 100F outside, but I could not get more than 3" of bead down before the tripping the over temp safety, then it was a mandatory 10 minute break. Took almost 3 hours to get the job done, most spent watching the machine cool off.
    Question for the OP: If you cannot fix your old welders, what makes you think you can build one?
  17. Likes Newman109, hermetic liked this post
  18. #14
    Nov 2007
    marysville ohio
    9,363
    2673
    6186
    Quote Originally Posted by dalmatiangirl61 View Post
    I have been using a Miller 35s since 1979, 1000s 0f pounds of wire through it 50 lbs at a time. I put a Bernard gun on it and a few liners, changed the grease in the feed motor and that's it. just run the shit out of it.
  19. Likes Ifitsmetal liked this post
  20. #15
    Oct 2005
    Wilmington DE USA
    2,003
    304
    409
    to the OP
    If you decide to build one, how about some pics.
    I have the remnants of a DC generator stick welder that someone built from plans in Pop..Scin.. magazine from the 60's, Surplus military generator powered by a Wisconsin 10hp motor. Actually used it on a construction site in the middle of the woods.
    But with prices of used equipment these days, building one that I would use evan occasionally doesn't add up
  21. #16
    Sep 2010
    Oklahoma City, OK
    4,321
    748
    1797
    Recommend thread lock, the red kind for hobbyist BS.
  22. Likes digger doug liked this post
  23. #17
    Apr 2004
    Wisconsin
    1,290
    6756
    1001
    Buy a Miller XMT304 and a S22 wirefeeder. Runs on single phase and makes beautiful welds. I have had mine for 15 years without a problem.
  24. Likes Ries liked this post
  25. #18
    Oct 2005
    15,133
    Quote Originally Posted by Cole2534 View Post
    2 post Kenny was probably:
    1. "Pub dialing"
    2. "A Fart in a windstorm"
    If anyone is welding that much, they don't have time to monkey around, and that much welding should pay enough to buy a good, reliable welder.
  26. #19
    Feb 2011
    1,155
    1019
    605
    Quote Originally Posted by moonlight machine View Post
    My Lincoln SP-200 will do that too, but it now lives in Nevada, I was in Tx. The point I was making is that the little cracker boxes are only good for light work, not serious welding.
  27. #20
    Oct 2019
    Washington
    Miller states the same thing for Mig as they do for Tig Settings. 1A for every 0.001" material thickness.
    Quote Originally Posted by Millerwelds.com
    1. Material thickness determines amperage. As a guideline, each .001 inch of material thickness requires 1 amp of output: .125 inch = 125 amps.
    MIG Welding: Setting the Correct Parameters | MillerWelds
