Can steel be welded to an impact socket?
Results 1 to 13 of 13
    Oct 2010
    Portland, OR
    718
    140
    248
    Default Can steel be welded to an impact socket?
    I need to make a custom deep socket. It will be a standard deep, cut in half (across the width), and then a tube and maybe some 1/4" steel welded to the sides (mostly to make it longer). It's just for assembly, no great amount of torque for the process. It's possible that JB Weld or something might work if welding won't work.
    The Dude
    Aug 2010
    Minnesota
    1,955
    148
    1443
    Absolutely.
  3. Likes The Dude, Joe Miranda liked this post
    Jan 2010
    North Carolina
    161
    251
    89
    Yes. I've TIG welded with regular ER70S2 rod. 309 stainless might be a better option for joining mild steel to tool steel. Attached is a special tool I made for torquing the pinion nut in a quick change rear end out of a 1-3/4" impact socket.
    Sent from my Pixel 2 XL using Tapatalk
  5. Likes Joe Miranda, Oldwrench liked this post
  6. #4
    May 2011
    New Jersey
    1,808
    167
    985
    I've done the exact thing at work for maintenance. I used er347 filler.
  7. #5
    Jul 2006
    Hillsboro, New Hampshire
    6,812
    1613
    4743
    If epoxy could work, why not just turn part of the OD for a heavy press fit to the drive tube?
  8. #6
    Oct 2010
    Portland, OR
    718
    140
    248
    Awesome, question answered, thanks!
    The Dude
  9. #7
    Jul 2009
    Peoria, IL
    11,669
    50
    8919
    I ran into a case once where the socket was made with leaded steel and could not be welded. I ordered one from another manufacturer and all was well.
  10. Likes PlasmaOnTheBrain liked this post
  11. #8
    Jun 2012
    Eastern PA
    917
    221
    406
    Yeah, impact sockets are generally a soft steel(so it doesn't break under the impacts). You won't know if you can weld it until you try.
  12. #9
    Dec 2012
    AUSTRALIA
    1,702
    7
    520
    Preheat and austenitic stainless filler...........Ive welded up thinwall sockets ,and they still are OK many years later......I also make sockets for specilaized jobs.and IMHO,the weld metal is stronger than the socket metal......I also welded the anvil of an old compact IR 1" impact gun when it developed deep cracks,and its still going strong....Its a handy old gun,its sort of doubled over,half normal length.
  13. #10
    Jan 2007
    Flushing/Flint, Michigan
    7,423
    365
    6216
    I modify sockets all the time, there is always something.
    Need a spanner for a bearing nut, chop four slots in a socket, bore the id and then add the black pipe extensions make it deep enough to clear the shaft end.
    Chromed sockets (which impacts are generally not), grind that chrome off in the mating areas.
    JB weld? A braze joint is maybe just as easy and much more reliable.
    Fancy specked rod is not needed.
    My go to is tig but arc stick or torch will do when that is what you have convenient at the moment.
    Bigger problem is that your socket set is always short since you use it as on hand stock.
    Bob
  14. Likes PlasmaOnTheBrain liked this post
  15. #11
    Dec 2012
    AUSTRALIA
    1,702
    7
    520
    CB,problem is easily solved......go to all the vintage car and bike swaps,and as well as highly priced bits of rusty Indian,buy some of the $5 a bucket sockets.....no use looking for valuable collector spanners tho,everyone knows whats what off ebay.
  16. #12
    Sep 2015
    425
    20
    170
    I’ve done it plenty of times. No need for special rod or filler. Don’t need a tig, just a decent mig welder will do. Or arc welder and some 7018 rod (6011 works too). More important is the fit of the tube you are using for the extension. And if you aren’t going to use it with an impact gun, then there is no need for an impact socket
  17. #13
    May 2010
    northern Indiana
    105
    11
    Done it many times. I always use a stainless non-hardening rod
