Carbide Chop Saw or Cold Saw?
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jan 2005
    NYC
    986
    11
    40
    Default Carbide Chop Saw or Cold Saw?
    We have a Haberlee350 in the shop, Great saw. I need something for "home" and though I'd pick up a use cold saw. However I've been looking at some of these carbide "Chop saws" and thought maybe that is all I need. I cut everything for .049" wall CroMo tubing to 4"Square steel, Aluminum and sometimes stainless. Can anyone give me an opinion about how these carbide saws work? I realize a chop saw isn't going to be a $5000 cold saw, but I don't think I need that, and even a good used one is $2K+
    Thoughts?
    Jul 2006
    Hillsboro, New Hampshire
    13,050
    2946
    8960
    Link to a couple examples of the machines you're interested in, that'll help a lot with feedback.
    Apr 2019
    Arkansas
    1,574
    750
    622
    We use the evolution brand saws and love them for chopping steel and aluminum bars up.
    They hold good cut tolerances and last a long time.
    Sent from my Pixel 3 using Tapatalk
    Jan 2005
    NYC
    986
    11
    40
    How straight and accurate are the cuts? Do you cut miter (non 90° angles)?
    I was looking at the trajan 1400:
    Carbide Steel Cutting Chop Saws for Carbide Circular Blades
    Apr 2019
    Arkansas
    1,574
    750
    622
    If you let the saw do the cutting they are straight, if you rush it you will see taper.
    Dec 2012
    Se Ma USA
    2,197
    179
    1198
    4" square steel bar will be no fun with a dry cut carbide blade. The saw will not have the power to keep that many teeth engaged in the stock making chips. Carbide teeth may not be happy either as longer engagement will stock will be a lot more heat because the teeth are rubbing the material away.
    I did see a cold saw at a show cutting 3" solid steel round stock like it was butter. A few seconds per cut. Not a home shop saw as I think it had something like a 30 HP motor. It was auto fed.
    Jul 2006
    13,050
    2946
    8960
    Going by this video: YouTube it's a step up from what you'd get at a Home Despot, but not a commercial grade saw. Sort of a semi-premium home shop tool. Aluminum base, small motor that likely will overheat with prolonged use, wimpy vise, etc.
    Might work for your application, but I'd want to see a fine tooth blade for your moly tube, or better "anti drop" blade design to prevent straddling teeth with thin wall cutting.
    Jul 2010
    Joliet Il
    98
    32
    39
    I use one of the Evolution saws at home for cutting thin wall 4130 tubing and the occasional piece of steel pipe or bar also, works great for that. I recently did a bunch of 304 s/s 1 1/2"-.049 for an exhaust system, and after about 12-15 cuts the blade was getting pretty dull (it wasn't a new blade to start with), I think s/s is asking a bit too much for this kind of saw. I also wouldn't think it would work too well for any solid section thicker than an inch or so. Generally I'm very happy with it for the hobby work I use it for though.
  9. Likes as9100d liked this post
  10. #9
    Jul 2013
    California, USA
    575
    636
    629
    I have two of these Slugger saws. One is the original Jancy and one the the Fein version now made in China.
    They are very accurate and cut well with the correct blade for the material being cut.
    Metal Cutting Saws - 14 in Slugger Metal Cutting Saw | FEIN
  11. #10
    Mar 2004
    Edison Washington USA
    10,805
    1132
    5935
    A cold saw is a completely different class of tool than those carbide chop saws.
    The chop saws are OK for thin wall tubing, or angle, but they are lightweight, built to a (low) price point, and will bog down pretty fast even cutting 1" solid, much less 4".
    You gets what you pay for.
    A decent cold saw can easily weigh 400 pounds or so, versus 50 for a chop saw.
    And a blade turning at 50 rpm, with continuous coolant, is going to outlast one turning 1200 rpm with no coolant every day of the year.
    Personally, I have found the best combo is a real cold saw, and a good bandsaw. But it costs more. My coldsaw blades run over $150 each, and, if you dont break em, can be resharpened for years.
  12. Likes mark in Portugal liked this post
  13. #11
    Jan 2010
    North Carolina
    205
    336
    106
    I had the DeWalt version of a dry cut carbide saw and agree with the other posters. It was great for round steel tube, OK for square and angle, but it really didn't do well with solids. Mitering square tube worked OK with a sharp blade, but one that had some wear didn't like cutting the flat surfaces of the square section. One downside to these saws is they're LOUD. The other is the chip collection isn't great. Still they make less mess than doing the same things with an abrasive chop saw and tend to cut straighter in my experience.
    I had a local guy that would sharpen the blades pretty cheaply, and would even braze new carbide on if you lost a tooth or two. He was very cost effective relative to buying new blades when they got dull. I could get 2-3 sharpenings on a blade before needing to replace it.
  14. #12
    Sep 2010
    Vancouver Canada
    1,035
    800
    414
    We have both a fixed in place Hyd-Mech cold saw, which is great for fine finish cuts on Aluminum, and a Dewalt carbide chop saw. The Dewalt is amazing where you wouldn't expect like cutting 8' steel C-channel. As noted above it's more like 30 lbs so we keep it stored away and bring it out to cut long stock in the middle of the floor of our limited space shop when needed. The vise on the Dewalt is rudimentary though, so setting up a square cut is a bit of a task. So they are sort of complementary but the chop saw is more of a production cutting tool to feed a machine shop where the Dewalt seems optimized for fabrication projects. I don't think we've tried to cut large solid stock on the Dewalt and the Hyd-Mech has a max size of like 90mm diameter. The Dewalt is overall great and would be ideal for home use by the serious fabricator/machinist.
  15. #13
    Jul 2006
    13,050
    2946
    8960
    Quote Originally Posted by rcoope View Post
    I have one too and agree it's a decent machine except for the vise. If I get some spare time I'm thinking of cobbling up something better.
  16. Likes mark in Portugal liked this post
  17. #14
    Apr 2021
    Idaho
    Hmm, I think you can find models that will cost less than two thousand dollars. There are a large number of circular saws that can be used at home. I have a WORX WX429L Circular Saw in my garage for many years and I can say that it has never failed me. You can learn more about this at trimthatweed.com, WORX WX429L will be the first in this list. the main thing that I can note is that this saw is Easy for one-handed use and that its weight and shape makes it very compact and convenient to work around the house. There are some other good models on this list. I think you can find something for yourself.
  18. #15
    May 2011
    New Jersey
    714
    17
    251
    That slugger one looks great. I had an evolution, couldn't stand the noise when cutting stainless. The vise was so cheaply made that it couldn't hold tolerances. It was just a crappy piece of bent material instead of a casting like the slugger appears to be
  19. #16
    Mar 2002
    dallas,tx
    2,679
    749
    551
    Just got a Morse 14" Metal Devil, for angle and tubing. Seems to work great. Construction and vise is quite good. Get the optional vise jaws.
  20. #17
    Mar 2005
    Indiana
    6,026
    2069
    2060
    Quote Originally Posted by edwardbarnett View Post
    Hmm, I think you can find models that will cost less than two thousand dollars. There are a large number of circular saws that can be used at home. I have a WORX WX429L Circular Saw in my garage for many years and I can say that it has never failed me. You can learn more about this at *spam removed* WORX WX429L will be the first in this list. the main thing that I can note is that this saw is Easy for one-handed use and that its weight and shape makes it very compact and convenient to work around the house. There are some other good models on this list. I think you can find something for yourself.
    Oh for spamming out loud...
  21. Likes digger doug liked this post
  22. #18
    Nov 2007
    E-burg MD USA
    649
    6
    114
    Hey Ya'll,
    Not to hijack the thread or anything like that.. Could I ask the wisdom of those present as to what type of blade life one should expect from a cold saw mitering 3 inch by 1/4 angle ? ( 45° mostly) (( a real cold saw, not a chop saw ))
    Tangentially to the OP.. I'm struggling through a job at the moment mitering the above material with a 14 inch bench top metal chop saw. ( Jepson ) Saw seems sturdy enough but the blade quality is all over the map.. Any suggestions as to what type of blade for 1/4 steel in a cold cut chop saw would be of help.
    Thanks in advance
    Stay safe
    Calvin B
  23. #19
    Mar 2011
    Providence RI
    351
    77
    58
    I just bought a femi xl120 portable miter bandsaw for job site use. I think it’s way better than any dry cut saw. It’s light weight, quiet and I can easily change the blade for the stock. It does not compare to my hyd mech coldsaw but for way it is it perfect. We only cut stainless steel with it abs just did a job where we had to cut a bunch of 3/4 x 2 true bar abs it worked like a champ. The head miters to 60° and it cuts up to 4”. I also have a Milwaukee cordless miters as for brass, but I would never put stainless or steel in it. The one I got cost $1300, but I think they have one size smaller for 8-900.
  24. #20
    Jan 2019
    Tennessee
    686
    203
    208
    Quote Originally Posted by calvin b View Post
    Hey Ya'll,
    Thanks in advance
    Stay safe
    Calvin B
    280 hss 3x3x.25 parts 45 on each end is one blade. Running a little on the hot side, but not all out. Blades are cheap to resharpen, keep a few on hand to never be without. On a scotchman cold saw with air over hydraulic feed. The cylinder leaks so I know I am starting the cut way to fast.
