Cast iron press brakes versus plate steel (Which ones are plate steel)
Results 1 to 16 of 16
    Feb 2009
    Midwestern MN/Wi USA
    1,363
    74
    379
    Default Cast iron press brakes versus plate steel (Which ones are plate steel)
    I recent discussion was noting that some chinese press brakes are cast iron. Does this not that seem rather dangerous considering the loads on the components?
    What machines are not cast iron
    LVD ?
    MVD ?
    AMADA ?
    BYSTRONIC ?
    TRUMPF ?
    BAILEIGH ?
    ACCURPRESS ?
    Oct 2005
    16,506
    Uhm...probably the ones sporting large welds.....
    Feb 2009
    1,363
    74
    379
    Most modern presses have the welds blended with ...whatever. If you walked up to a press you would need a chipping hammer to tell these days
    Oct 2009
    Oregon
    4,556
    4914
    2361
    Never seen a press brake that was cast before.
    I would think if it was cast it would be cast STEEL no?
    Seen biggun stamping presses thqat are cast iron, but they have huge steel tension rods to take the force.
  5. Likes digger doug liked this post
    Jul 2004
    Houston, TX USA
    30,434
    Absolutely
    Like our 600 ton Pacific
    Cast steel for tough stuff like the running gear on this 1899 85 ton job. See? Cast steel has been with us a long time
    Feb 2009
    1,363
    74
    379
    Some press brakes about 10 years ago were poorly made chinese castings and broke apart when forming a bend. I have seen pictures. I was just wondering without actually going to see each one if any of the above in the modern age are cast or if they are all cut from plate.
    Sep 2006
    Sacramento County, California
    3,867
    2437
    1361
    I've looked at cheap Chinese 10 and 20 ton presses sold by Harbor Freight. They come with two plates to press against. They are extremely dangerous since they are made of cast iron and will very likely break if used to support work items under pressure.
    No, I didn't buy one of the presses. I have an old Taiwan-made unit that came with steel plates for that purpose.
  9. #8
    Oct 2005
    16,506
    Quote Originally Posted by Newman109 View Post
    How did you determine they were cast iron, and not cast steel ?
  10. #9
    Sep 2006
    3,867
    2437
    1361
    Good question. That said, we are talking about Harbor Freight. If you had to guess, would you guess cast iron or cast steel? To tell the truth, I made no tests in the store, but I'd bet on cast iron.
    I wouldn't take a chance on it, but it sounds like you might.
  11. #10
    Oct 2005
    16,506
    I don't guess, I test.
    A simple drilled hole will prove fruitfull.
  12. Likes Newman109 liked this post
  13. #11
    Sep 2006
    3,867
    2437
    1361
  14. #12
    Oct 2013
    The Gorge, Oregon
    172
    35
    130
    If you get it cheap enough you may worry the plates are cast iron, but you can always just get some plate water jetted from your wholesaler or your scrap bin to be safe.
    This thread brings up the point that stuff explodes or gets cocked in presses and just goes flying at high speed. It makes sense to put a screen around the front and to the side where you stand. I had some of the lumpy HF press plates that were so unflat that they were dangerous to use. Tried to flatten one in the mill and what ever was used to cast those things ate carbide. Ended up using them as bases under gate posts in my field.
  15. Likes Newman109 liked this post
  16. #13
    Oct 2009
    Oregon
    4,556
    4914
    2361
    How does a harbor freight shop press have even the remotest relevance in a discussion about press brakes?
  17. Likes johfoster, Fish On, digger doug liked this post
  18. #14
    Dec 2012
    AUSTRALIA
    2,578
    10
    803
    Dunno,any cast iron pressbrakes Ive seen were giants and generally 100 years old......but they are still working bending 12 ft lengths of 1/2 plate,and I think a modern machine in that class would be spendy......Furthermore,the OP has apparently not heard of SG cast irons,with yield strengths far in excess of his beloved boiler plate.
  19. #15
    Mar 2011
    Geneva Illinois USA
    6,335
    2743
    2468
    Check out the stress-strain diagrams of the various materials. Yield point by itself is not significant.
    Tom
  20. #16
    Apr 2018
    3,692
    1671
    Quote Originally Posted by Garwood View Post
    It just gives people a reason to snivel about China again. I had a 1970 Pontiac, too, I mean wtf, over ?
