Anyone know anything about this machine? I'm looking for a plasma cutter that can cut up to 12mm nicely, and sever bigger stuff. This is an old 2nd hand unit and was made in Italy. Looks pretty solid, weighs 85 kilos and is three phase driven (a requirement). I understand it's not as effective per amp as a modern unit, only rated to max 20mm which is a lot less than a 70A modern unit would do. But I can live with that, personally, if it's durable and does a good job inside it's performance sheet.
But what's this about older units using up consumables and torches faster? How is the cut quality? Also is there a differnce between single and three phase transformer units. I know that's a big diff in welders, a 1ph transformer rectifier puts out a pretty shitty arc when stick welding, but a 3 phase one feels as smooth as an inverter. Same deal here maybe?
I've heard some people tell me this old unit will work really well if I put a modern torch on it. I figured the torch was just the torch, like on a TIG machine, nice to have a nice one but it's the machine that matters most.
