I need a closed loop setup and an srs put together for multiple machines. The SRS setups I can go without for a while if needed, but also I don't have much worry about piecing one together that will work.
The closed loop filtration I am having more questions about. I have a chiller already, and I probably have enough surplus pumps laying around here also. Building an open tank no problem either. Is Ebbco the only game in town for the filter housings and elements? Have any of you pieced together your own setup before?
I was on a budget before, but with everything going on right now saving $5k here and there has become worth the effort at the current moment until I have these up and running. Thanks.
