dplucinski
- Jun 23, 2016
I'm in the market for a tube bender and my Googling has uncovered machines I like, but none with all the features I want.
I will be bending the following:
And the features I'm looking for:
I've looked at the Baileigh Industrial roll benders, but we really need the automatic edge sensing for idiot-proofing and efficiency. We will be doing runs of 100+ of the same program.
- 28mm OD, 0.7mm and 1.2mm thick stainless steel.
- 28mm OD, 1.0mm and 2.0mm thick steel pipes w/ ABS coating ( https://www.seekpng.com/png/full/628-6287434_pe-abs-pvc-plastic-coated-steel-pipe-for.png )
- Automatic edge sensing
- Modern controls and connectivity
- Loading file from the network
- Different radiuses in one length of tube (roll bending required?)
