Question on Esab 253
Don Gitzel
Jul 25, 2017
D4196645-3680-4287-B739-3BF288C4254C.jpgD4196645-3680-4287-B739-3BF288C4254C.jpgI have been trying to get a manual online from Esab’ site. They offer nothing on the 253 I need to know what the control knob reading from O-10 with several dots beside. I suspect it a pulse feature but I don’t know how to use it. Also I wanted to put a smaller reel of wire on it but could not remove the large spindle. Can anyone shed some light on the 253. Is it Esab’s entry level machine? You guys are awesome with such a large knowledge base.
Post a picture of the whole front panel with all the controls.
It looks like the lower knob is wire speed and the upper could be pulse, spot or stitch weld timing. Need more visual for more info...
Good luck,
Matt
1F2B204D-FF6D-4F96-862C-FED1925054D4.jpg1F2B204D-FF6D-4F96-862C-FED1925054D4.jpgRepaired frame with .035 steel wire set as per chart heat high on 12 and wire speed 7. Seems like is hot however high buildup. Will keep practicing.
