Concerned About Miller Quality - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 63
  1. #21
    Jul 2010
    corvallis,or
    854
    89
    356
    Quote Originally Posted by gregormarwick View Post
    As with many other things, you're doing yourself a real disservice by limiting yourself to domestic manufacturers.
    I rarely do any welding, but everyone I know who uses them talks very highly of Kemppi.
    They look cool, however, with no distributors, parts or service in the US, I can't imagine anyone in the US buying one.
    Teryk
    Sent from my XT1710-02 using Tapatalk
  2. #22
    Feb 2007
    Aberdeen, UK
    3,572
    1237
    1350
    Quote Originally Posted by mTeryk View Post
    Teryk
    I found that hard to believe so checked, and sure enough you're right.
    They are literally everywhere in the world apart from NA, they're even right on your doorstep in Mexico. Politics?
  3. #23
    Dec 2003
    Washington
    4,677
    2191
    3996
    we are 2-1/2 years in on a new Dynasty inverter based TIG welder - this thing hasn't missed a beat and it gets used every single day for a huge variety of welding tasks. I think you just have a crappy local service provider.
  4. Likes Ohio Mike liked this post
  5. #24
    Oct 2005
    15,132
    Quote Originally Posted by motion guru View Post
    How can the local people keep it from failing ?
  6. #25
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,154
    1019
    605
    They can't, but the "tech" that is also in charge of bottle filling and floor sweeping can't fix it either.......
  7. #26
    Oct 2005
    15,132
    Quote Originally Posted by dalmatiangirl61 View Post
    The OP has had "failures" in his/her shop.
    Then it goes into the LWS for "repairs"
    Yes the LWS is failing from a "repair" standpoint, but if Motion's machine never needs repairs, how would the good or bad LWS be a factor ?
  8. #27
    May 2009
    Wyoming
    3,239
    7836
    5211
    Quote Originally Posted by Ries View Post
    ...I have a friend who autongenous welds schedule 10 stainless pipe, for breweries, where every weld must be 100% perfect. The new Miller inverter tig he uses, on jobsites in breweries, does things that the old P&H refridgerator sized machines just could not do.
    Boy, did that exactly cover why I sold the big P&H. It had the adjustable waveform option (big handle like some kind of clutch on a locomotive or tugboat) and you could do some nice work with it—but nothing like the instant adjustment possible with the Dynasty that replaced it. The Dynasty is smaller than the chiller that used to sit on top of the P&H. Yes, the P&H also had a coil of 4/0 wires so I could run stick at 400 amps if I wanted to, but that got to be pretty high on the list of things I no longer wanted to do.
    Local welders would gaze at the P&H with envy but it was like how I used to drool over a Monarch NN or an American Pacemaker and then remember, Oh, wait a minute, I have CNCs.
  9. Likes dalmatiangirl61 liked this post
  10. #28
    Jan 2006
    Angier, North Carolina
    2,603
    1086
    966
    If you are not satisfied with Miller quality ...
    ... time to switch to Budweiser!
  11. Likes MichaelP liked this post
  12. #29
    Dec 2018
    Indiana
    98
    10
    Personally think the inverters are way over rated in terms of duty cycle. I just don't think they can be ran balls out all the time. Im stuck with them for now because it can go down to 1 amp which I need on some parts. Ive only ever seen 2 miller inverters go bad out of heck guessing 40-50 over the years at different places Ive worked.
    First inverter I ever used was an old thermal arc. Was my favorite for 200+ amps TIG welding. Have heard they suck now but don't know.
  13. #30
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,982
    1455
    2413
    OP....while you're waiting and down without a machine, go by one at Harbor Freight. Use it for 90 days and return it if you don't like it.
    If it fails in that time, take it back and they'll give you a new machine, no questions asked. Because it sounds like even HF has better service
    than the people you've been dealing with. Maybe you should even spring for the extended warranty.
  14. #31
    Aug 2010
    Santa Cruz, CA USA
    170
    257
    64
    I've had my Dynasty 200 for a little over 9 years now, in use every day in both production and job shop work. Except for the shit water cooler it came with it has had zero problems. I have a 350p mig welder that had a bad board in the first year of very light use, covered under warranty, and been running good for about 5 years now. The little Miller 150 gets very little use (tacking stuff up in the field) but it's great when I need it and has never hiccuped. My Syncrowave 500s is a beast, it just keeps running, (it creates enough of a magnetic field that the fan on the wall above it spins when you strike an arch with higher amperage) it's mainly used for thick aluminum jobs and not for production. Overall happy with our Millers.
  15. #32
    Feb 2014
    Cartersville, Ga
    234
    57
    126
    Quote Originally Posted by turnworks View Post
    The older sanrex made thermal arx machines were awesome. I still make my living with one, and love it.
    Then, the name got sold, and the new thermal arc branded machines are basically hobby grade machines, made in China.
    That said, I ran across the sanrex booth at fabtech let year. There actually is US distribution for Japanese made Sanrex machines, so you can still get brand new units. I'm hanging onto Atlanta distributor's flyer, she will give that a long look when it comes time to get another TIG power source.
  16. #33
    Oct 2009
    Oregon
    4,192
    4497
    2131
    Quote Originally Posted by gary-sc View Post
    So you bought a new one in the past 2 years eh?
  17. #34
    May 2009
    Wyoming
    3,239
    7836
    5211
    Quote Originally Posted by awake View Post
    Once on the DC Beltway in the early 70s I passed another welding truck, also with a big Perkins-Diesel-powered Miller on it—but his had had the Miller logo decal carefully removed and replaced with a big Miller Beer logo. I imagine he drew steering-wheel-pounding guffaws from every other welding truck that saw it.
  18. Likes awake liked this post
  19. #35
    Aug 2010
    Santa Cruz, CA USA
    170
    257
    64
    Quote Originally Posted by Garwood View Post
    No I haven't
  20. #36
    Oct 2009
    Oregon
    4,192
    4497
    2131
    No I haven't
    Good luck if you do.
  21. #37
    Oct 2011
    West-Central Illinois, USA
    1,239
    1999
    564
    To the OP I’d advise any salesman of your intentions to mig weld 1/4” a lot. A good one wouldn’t sell you less than a 250amp 60% duty cycle machine (that would be the minimum). hawkfan9 in post #2 has one in the 1989 MM220 (really 250 @ 60% but labeled for 100% DC).
    I think this is all price points & markets against buyers & sellers. My PM300mp (now the 350mp from lincoln, just re-badged) in 2003 = $3,200 & is now $5100ish. It’s 230amp @ 100% which would allow for constant welding 1/4” at proper heat input vs travel speeds (all materials). I’m a little unsettled about gary-sc’s experience with the 350P (similar price $$$$ machine) as they have been good over the years for CV (all-mig) welding machines???
    About the square wave tranny tig’s, both blue & red show very high input currents if they have PFC’s in them. The voltage leak back to the power meter is very small so the bill reflects about the same as 100-150watt light bulb. Explaining WHY they are in there (when they are) would be for another thread (my red 1998 SW275 doesn’t have them & it limits high current AC at out of balance settings). Nevertheless, these machines SHOULD run 40,000hrs+ MTBF but with all the copper they’d top the price of the newest big Dynasty…
    I have the mid-80’s Kemmpi MP1500 trio inverter that’s 60% duty at 150amps. It’s a welding fool with .030” wire for tube cladding. It needs 52amps at 110V or 26amps @ 220 (you read that right!). These carried Lloyds highest ratings so they’re ship happy puppies. Little known fact about them was you can drop the power supply, hook the neutral AC input and the ground cables to the ship structure and then carry the 1 hot AC input voltage cord to the machine plug… Slick as shit (but how do it know what’s neutral and what’s work ground??? → it just does… The CC (stick side) isn’t quite up to the 3/4” weld mold rod by it below. Price late 80’s $2400ish...
    Hoping for everyone's sake all the bad ones are outliers (at proper specs & prices).
    Good luck
    Matt
  22. #38
    Jan 2008
    Orlando,FL, USA
    96
    356
    23
    Quote Originally Posted by Matt_Maguire View Post
    Good luck
    Matt
    Matt,
    Would that also apply to a non-squarewave TIG 300/300 as well ?
    Thanks.
  23. #39
    Oct 2011
    1,239
    1999
    564
    Quote Originally Posted by Kiwi2wheels View Post
    Matt,
    Thanks.
    No, the grey & red 300/300’s did not have square wave trickery and AC balance control so there are no power factor correction caps in them. They DO have big ass cooling fans though that run constant (800 wattish) and a really big lump inside.
    Good luck
    Matt
  24. #40
    Mar 2017
    New Mexico
    12
    Thanks every one. I see allot of good comments both ways. I prefer to stick with American brands. My thought is to buy the Miller Multimatic 255 as it has allot of features I like but also buy the Ranger 330 from Lincoln. I'm looking to use the engine driven unit for double duty. It would primarily be the backup generator for my house but also have it on a trailer ready for transport to a site. I have heard of folks doing this and like the idea especially since it could deliver 10Kw at the same price as a standard stand alone generator. By buying both brands I'm covered, when the Miller breaks I have the Lincoln and vice versa.
    Thoughts?
