rbcmetalwork
- Feb 11, 2008
- Honolulu, Hawaii
I have an Enerpac PUD-1100B electric hydraulic pump. This is an economy model does not have a hold feature. It does have an electric solenoid dump valve. A momentary switch runs the pump which advances a single acting cylinder. Releasing this switch opens the solenoid valve which dumps the fluid back to the tank.
Can I re-wire this so that the solenoid valve is energized and closed until I switch it off causing it to dump the fluid? Opinions/advice?
