Crazy welding
Results 1 to 7 of 7
Thread: Crazy welding
    Jul 2017
    CANADA
    Alberta
    77
    23
    Default Crazy welding
    You must have seen videos of a cold welding process coming out of China. It’s also called crazy welding. I cannot find a source for the machines but I think it would work well for installing auto body panels. Does anyone have any experience with this method of welding?
    May 2019
    Michigan
    1,402
    387
    627
    J B Weld...??
    Or maybe what we call "friction stir welding" when someone makes a typo in a program and uses what's left of an endmill to extrude material........
  3. Likes steve-l, Garwood liked this post
    Oct 2005
    17,694
    G.E. invented cold welding of strip materials in the 1950's
    Machine was quite large (hydraulic press) and had polished dies to mash the material together.
    Very limited usage.
    May 2011
    New Jersey
    649
    14
    220
    Weld body panels... yeah right. All that stuff is glued together with panel bond now.
    Feb 2013
    Northern califorina, usa
    322
    105
    Cold welding is at times referred to as Diffusion welding, Cold welding is a solid state process in which pressure is used at or near room temperature to produce a type of coalescence of metals with considerable deformation at the cold weld zone. Pressure for welding can be from a number of different types of systems such as mechanical presses, rolls and in some cases for very small work even hand operated tools.
    With this process there is a total absence of heat created during the process.
    Soft materials are best suited for cold welding, hardened or heat treated alloys are more difficult and in some cases imposable to cold weld.
    One of the useful aspects of this process is that dissimilar metals can be joined in this process. The process is far from new ,it's been around for years.
    Dec 2012
    Se Ma USA
    1,735
    138
    949
    Sheets of aluminum are welded to steel plates but the process is not exactly cold. lots of explosives involved.
    Feb 2013
    322
    105
    Quote Originally Posted by Scruffy887 View Post
    What you describe is not at all like cold welding, Explosive force is not used.
