taiwanluthiers
Cast Iron
- Dec 6, 2016
- Xinjhuan District, New Taipei City
I have a Chinese 50 watt laser. I have just changed the laser tube to a 55 x 1250mm tube (it originally came with a 50 x 800mm tube) that the manufacturer claims to be 80 watts. I did not replace the power supply because I don't have money to buy a power supply but I will change it shortly as well. Initially the tube wasn't outputting much power but after showing the seller he told me to rotate the tube so the water inlet is facing down. For some reason this fixed it. I plan to get a 150 watt power supply in the future...
I tried cutting thick, 12mm plywood. However while it cuts anything up to 9mm easily (with the new tubes), I find anything thicker just burns no matter how many passes I take. In fact I did a test with plywood where I would just cut very slowly, and what happens is the wood always burns. Is there an upper limit to laser cutting plywood?
I tried with plastic and I can even cut 19mm thick plastic either with multiple passes or very slow speeds (65% power, 1mm/s) and while the cut quality isn't great, it cuts.
So what's the deal? how can I cut thick plywood? more power?
