iuctx
- Jan 24, 2019
- Fort Worth, TX
I am trying to find the best type and size fan to exhaust the smoke/fumes/dust from my table. The table is 6x12 and has a v-shaped basin. Suspended halfway between the basin bottom and the cutting surface is a 7" ID steel pipe with 8ea 4" square 'ports'. There is only one outlet on the table located on one end. The table will be situated in my shop in such a way that the outlet of this pipe is 8' from the exterior wall, at 90 degrees from where I need to vent.
I have read good things about backward incline blowers. Any input on what size and type fan as well as connection methods will be much appreciated.
