Enerpac hydraulic pump modification
Results 1 to 7 of 7
    Feb 2008
    Hawaii
    215
    5
    30
    Default Enerpac hydraulic pump modification
    I have an Enerpac PUD-1100B electric hydraulic pump. This is an economy model does not have a hold feature. It does have an electric solenoid dump valve. A momentary switch runs the pump which advances a single acting cylinder. Releasing this switch opens the solenoid valve which dumps the fluid back to the tank.
    Can I re-wire this so that the solenoid valve is energized and closed until I switch it off causing it to dump the fluid? Opinions/advice?
    Oct 2005
    16,595
    I think it's wired backwards as it is.....
    IIRC after the pump shuts off, it should hold until you
    energize the solenoid to dump back to tank.
    Feb 2008
    Hawaii
    215
    5
    30
    Per Enerpac
    "PUD-1100B/E and PUD-1101B/E Models
    The PUD-1100B/E and PUD-1101B/E operate single-acting
    cylinders where the hold function is not necessary. Pressing the
    pendant switch starts the motor and advances the cylinder. When
    the switch is released, the cylinder will retract."
    Oct 2005
    16,595
    Quote Originally Posted by rbcmetalwork View Post
    Per Enerpac
    Do you want my help or do you want to play lawyer ?
    Pretty much every enerpac style pump I have encountered is as
    I have written.
    What would be so bad about you unhooking qty (2) wires to the solenoid, and putting them on the other push button ?
    Better yet, add a DPDT switch (and nicely labeled) to switch
    the action of the pump/pushbuttons, enabling you
    to simply switch back to the original configuration.
    Feb 2008
    Hawaii
    215
    5
    30
    I'll try it. Thanks, Doug.
    Dec 2010
    WA, USA
    1,505
    2062
    1040
    Alternatively, rather than modify the Enerpac pump unit, voiding any warranty and turning it into what it ain't, you could add (between the pump and the cylinder) a check valve and a secondary "return to reservoir" path controlled by a valve or solenoid? YMMV
    By the way, I appreciate (am not offended by) your quoting the Enerpac catalog description. It shows you've done some homework.
    No doubt, Doug will soon pass that bug that's crawled up his arse.
  7. Likes 4GSR liked this post
    Jan 2020
    Florida
    Yes I realize that this is a very old thread.
    Bought a HK PORTER HKE102A, which appear to be similar to the low end Enerpac hydraulic pumps. It only would extend and as soon as you released the motor switch, it would retract. Not what I was looking for...
    It has the hold solenoid, but it is wired to close the return only while the motor operates. So I Re-wired it to allow for separate control of the "Hold Solenoid".
    Now; Motor button depress, extends ram, releasing motor button the ram is in hold,
    Operating new "Release" button , and the ram retracts. Ram also retracts when main power is removed.
