Toggle Brain
- Aug 7, 2017
While cutting 3mm steel sheet I noticed an improvement in the arc stability of the cutting process. Unfortunately this is now combined with arcing to the work piece through the nozzle. I can burn through paint now but the thing behaves like a drunken harry potter wand.
- machine is a 40 amp Asian build
- all torch consumeables replaced
- torch checked for cracks and faulty lines
- internal circuits checked for escaped smoke (none)
- internal circuits partially reverse engineered for analysing the theory of operation
- push button start activates a relay controlled air valve only, no direct control over arc starting
- arc starts by the presence of voltage on the output terminals through an inductor and resistor network on the base
of a transistor which closes a relay on the HF transformer supply lines..(diagram attached)
any help, suggestions or open ears appreciated
