If I was younger, I would learn to weld. But, at 80 years, well, you get the idea...I'll be dead before I learn the necessary skills.
So, I have this project. I want to fab up a carrier for a 55 gallon poly barrel that will attach to the Cat 1, 3 point on the rear of my tractor. Pretty simple really...I'll make a sketch, cut the angle iron I have here at the ranch and acquire all the needed hardware. Then, I'll need a person who welds to either show up and do the welding, or, I can bring the bits along on my trailer to your shop...either way...doesn't matter. But, I'm having difficulty finding a welder to do the job. It is likely about an hours work. The degree of precision is low and I'm not fussy about the appearance of the welds.
Any of you out there near the 282 mile marker on I-65 in Alabama?
Let me know.
Thank you.
Let me know.
Thank you.
