Finger brake radius question
Results 1 to 9 of 9
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Default Finger brake radius question
    I recently picked up a small finger brake to make some aluminum boxes and what I'm wondering is how to properly determine the bend radius for specific thicknesses of sheet metal. Right now it's all 14 or 16 gauge aluminum.
    Does anyone have other rules of thumb they'd like to share?
    Thanks, Cole
    Jan 2010
    North Carolina
    170
    267
    90
    Here's a decent article on basic brake setup:
    Adjusting Your Sheet Metal Brake : Irvan-Smith, Inc.
    With a finger brake the exact bend radius is going to take some trial and error to dial in. Setting the fingers back will give a larger bend radius, as will bending with the angle installed on the apron.
    Mar 2004
    Edison Washington USA
    10,342
    964
    5344
    the alloy of the aluminum, and the thickness, both matter quite a bit.
    Here is a chart which shows how it varies depending on the alloy or metal used.
    Minimum Recommended Bend Radius Chart from American Machine Tools Company
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Awesome, thank you both!
    Jul 2004
    Houston, TX USA
    29,659
    It will be surprising how the act of bending will simply move the stock - without a back up to prevent that happening
    Thumbnail is one I made for my Pexto before I sold it
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Brake doesn't currently have a back gauge but one is on my list to fabricate.
    I'd not mind some pics of shop made arrangements if anyone has some handy.
    Mar 2005
    Kansas
    7,432
    426
    3406
    An apron brake won't give a smooth radius like a press brake. If that's important, you have the wrong tool.
    Standard is to set the top leaf back two times your material thickness.
  8. Likes steve-l liked this post
  9. #8
    Sep 2010
    Oklahoma City, OK
    4,249
    730
    1784
    Quote Originally Posted by gbent View Post
    Perfect.
    No need for perfect radius here, just building some small boxes and sheet metal panels to replace some that have been damaged over the years.
    It seems that if the brake is good for 16ga mild, that about 20ga stainless is its limit. That a fair estimate?
  10. #9
    Jan 2010
    North Carolina
    170
    267
    90
    Yes, generally speaking you need to derate by 4 gauges for stainless.
