I am trying to straighten out these hand rails that I didn't build , initially I was going to shorten the two center stanchions but thought I would try flame bending as they looked to have too much sheer in them , first one turned out perfect after two attempts at spot heating the reverse way I wanted it to bend but the second one is stubborn. Still trying to get one end down 1/2 inch. Is it better to just put a few heat spots at a time or is heating the whole distance a better or worse technique. I wish I had an 8 ft. Welding table to clamp it to and then use a porta power but thought I would try the heat technique but I don't have much experiance heating . 1 1/2 inch schedule 40 ss pipe. Appreciate any suggestions.
Sent from my iPad using Tapatalk
