Anybody here has experience/recommendations on putting a large flare into the end of steel pipe using a lathe?
Pipe is 12" o.d., 1/4" wall (the piece is about 14" long). I'd like to put a pretty large flare into one end-- say about a 1" radius, and take it out to as much as perpendicular (90 deg).
Was thinking about setting up an oxy/acetylene torch w/ flame spreader positioned to heat the end of pipe as it turns, and mounting a roller bearing tool in the tool rest, to run against the inside end of the pipe and gradually flare it out to the desired profile.
Any thoughts on this?
