Halide
- Aug 8, 2012
- orange, CA
I am programming and operating an Integrated Flying Bridge 50i. The machine is 7 years old and has 5400hrs on it. It is a fixed head with a 50 horsepower motor pushing a 60ksi single intensifier pump. The machine was originally installed (before me) with a windows 98 pc. About 4 yrs ago management made the decision to upgrade the pc to windows XP running flowmatser6.0. Thank God! My problem is the machine is shutting down at random intervals. Sometimes a small generic window opens on the terminal with a red X and an “ok” button, and other times the full size error window shows up informing me to check Flow diagnostics. Regardless of the window, the shut down code indicated on the Flow diagnostics menu is always the same; intensifier overload P201.
Previously, shut downs were seldom making it an occasional inconvenience. However, occurrences have increased over the last 4 months to between 9 and 14 shut downs in an 8 hr period. Flow has sent out a tech twice. The first guy did not know what to do. The second told us we need to replace the inlet water charge pump. We just happened to have a pump on hand with a relief valve assembly attached. Yet, the next day the shut downs persisted.
The latest diagnosis is that the motor needs to be replaced or rewound. We have had electricians look at the machine. Some have agreed with this diagnosis, and others are not sure. The latest guy said we should put coolers on the controller cabinets. I finished the installation yesterday. today I had 4 shutdowns in a 1hr period. The electrician tells me he will obtain a mega ohms meter to check the winding on the motor.
Any advice?
Any advice?
