AccuTrex uses state-of-the-art technologies and manufacturing process to produce custom peelable washers.
Stamping – Stamping is the most common type of peelable washer fabrication, especially for larger quantities. Parts are consistent, with high repeatability during production. AccuTrex builds and maintains your custom tooling in-house. We also maintain a large inventory of standard OD and ID dies and ring dies that can be used to reduce costs and eliminate extra tooling charges. We provide a full range of stamping services to provide you with a finished part.
Waterjet cutting – Waterjet cutting is used to cut washers out of materials that cannot be laser cut, such as brass and laminated materials. Our CNC-controlled waterjet cutting machinery can cut materials up to 6” thick. Tolerances are based on the size and thickness of the material being cut.
Wire EDM cutting – Wire EDM is used for metals that can be difficult to cut or shape with other methods and for washers that require very tight tolerances.
